Need Help.. injectors.
FPR is at 60psi "no vac" and needs more gas.
engine is in a 90 teg "non obd" using stock b18a injectors.
mods:
b18c1
pr3 pistons
Skunk2 IM
P&P
ITR camshafts
DC 4-1 headers.
Cam gears
Vafc
FPR
y1 lsd cable tranny
I was told that the H22 injectors will work with non obd..
To make things short, i need bigger injectors, and i'm thinking maybe the h22 is way too big. what other injector will work with non obd.
what about b20a/b from late preludes.
Or is there a site that compares injectors.
All help is greatly appreciated.
with my setup. no intake and no exhaust.. i ran 140whp. i'm not very happy.
GsTeg90
mods:
b18c1
pr3 pistons
Skunk2 IM
P&P
ITR camshafts
DC 4-1 headers.
Cam gears
Vafc
FPR
y1 lsd cable tranny
GsTeg90
What graphs? You cannot add fuel with your afc in those certain places?
Turn the fpr down to stock and adjust your fuel with the afc.
I dont see why your setup would need bigger injectors. I am using stock injectors (w/ bumped fuel pressure) on my crvtec.
Turn the fpr down to stock and adjust your fuel with the afc.I dont see why your setup would need bigger injectors. I am using stock injectors (w/ bumped fuel pressure) on my crvtec.
