H22 Wont Start!!!
Old May 4, 2003 | 04:13 PM
junglerunna's Avatar
Default H22 Wont Start!!!
Yesterday I drove the car and put about 50 miles on it. Today I go out there to start it and the engine turns over but wont start. Its getting fuel, but there is no spark. The only codes I have are the EGR, and some traction code I forget what it is. I am also getting voltage to the distributer. Its just very strange yesterday it started up fine, no problem, fired right up. Then today go out there to start and its just no firing. I dont know what to do?
Old May 4, 2003 | 04:17 PM
fastwanabe's Avatar
Default Re: H22 Wont Start!!! (junglerunna02)
IM sent
Old May 4, 2003 | 04:24 PM
poison's Avatar
sent ya response via IM
Old May 4, 2003 | 04:26 PM
Default Re: H22 Wont Start!!! (poison)
How come I didnt recieve any bodys im? Todays a bad day.
Old May 4, 2003 | 04:27 PM
poison's Avatar
wtf? I sent ya IM like 10 min ago too.
How far have you gone on the Helms troubleshooting? I'm thinking it's the ignitor, but too little information to narrow down the problem.
Old May 4, 2003 | 04:30 PM
fastwanabe's Avatar
yeah I sent my IM like 10 min ago aswell.
anyway I needed to know how you check for fuel and spark. did you check the Tbelt?
Old May 4, 2003 | 04:31 PM
JDMH22HATCH's Avatar
Is it internal or external coil distributer? Check the coil and the Ignitor. If internal, the coil can be used from any D or B series obd1 distributer. The ignitor can be used from B series as well. Good luck.
Old May 4, 2003 | 04:33 PM
Its 94 H22. Im using a P13 ecu. If we swap D series dist what should I do next. Will the TDC sensor have anything to with no start. Also the tach doesnt work when I try and crank it
Old May 4, 2003 | 04:37 PM
fastwanabe's Avatar
your d series distributor wont bolt up but you can have somone hold it on while you crank.
if the tach dont work I would lean toward the ignitor being bad, thats inside the distributor.
Default Re: H22 Wont Start!!! (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">Is it internal or external coil distributer? Check the coil and the Ignitor. If internal, the coil can be used from any D or B series obd1 distributer. The ignitor can be used from B series as well. Good luck.</TD></TR></TABLE>
Its an internal coil, stock dist. No I didnt check the coil, and for the ignitor, I couldnt find in the helms how to really check it.
Also if I swap dist from the d16 and it doesnt work where should I go from there.
Old May 4, 2003 | 04:38 PM
Default Re: H22 Wont Start!!! (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">your d series distributor wont bolt up but you can have somone hold it on while you crank.
if the tach dont work I would lean toward the ignitor being bad, thats inside the distributor.</TD></TR></TABLE>
ANy specific way to check for the ignitor being bad?
Old May 4, 2003 | 04:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">wtf? I sent ya IM like 10 min ago too.
How far have you gone on the Helms troubleshooting? I'm thinking it's the ignitor, but too little information to narrow down the problem.</TD></TR></TABLE>
Just recieved im's now. I pretty went through as much troubleshooting for the igntion as possible.
Old May 4, 2003 | 04:44 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 &raquo;</TD></TR><TR><TD CLASS="quote">
ANy specific way to check for the ignitor being bad?</TD></TR></TABLE>
its in the Helms under all the distributor stuff, just look for it slowly it on 1/2 a page very very easy to miss.
Old May 4, 2003 | 04:47 PM
its in the Helms under all the distributor stuff, just look for it slowly it on 1/2 a page very very easy to miss.</TD></TR></TABLE>
Prolly why I missed it. Ill try all this tomorrow after class, see what I can come up with. Thanks everybody
Old May 4, 2003 | 05:04 PM
Jason kiDD's Avatar
The best way to know if the ignitor is working or not is to check for spark. If you need help on how to do that then let me know and I can walk you through the process..
And if it is indeed back I have a spare lying around the house somewhere..
Old May 4, 2003 | 05:09 PM
Default Re: (Jason kiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD &raquo;</TD></TR><TR><TD CLASS="quote">The best way to know if the ignitor is working or not is to check for spark. If you need help on how to do that then let me know and I can walk you through the process..
And if it is indeed back I have a spare lying around the house somewhere..</TD></TR></TABLE>
Alright thanks ill let you know.
Old May 5, 2003 | 02:59 PM
Default Re: (junglerunna02)
Coil was bad. I swapped it with the coil from my d16, and she fired right up. But I can not figure out why the coil just all of a sudden went bad?
peter17212
Mar 30, 2009 07:40 AM
peter17212
10
Feb 8, 2008 04:48 PM
jchrm80
Jul 20, 2007 08:13 PM
dan89crxsi
Feb 10, 2007 02:44 PM
hyabusa hunter
Jul 6, 2006 08:51 AM
