Oil light on. B16. HELP!
Old May 1, 2003 | 07:08 PM
94CivSi's Avatar
Default Oil light on. B16. HELP!
I just got my swap running, however my oil light is on. Is this common? Am I missing something simple in my swap, or do I have a real problem?
EG hatch, B16.
Old May 1, 2003 | 07:37 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Oil light on. B16. HELP! (94CivSi)
Make sure that the drain plug is on and check the oil filter is on tight. do you have an oil pressure gauge? check the oil and make sure that you have oil in there. Best way to tell. Also do you have the oil sensor hooked up>
Blaze
Old May 1, 2003 | 07:50 PM
poison's Avatar
yeah, put oil in and make sure your oil filter is on
Old May 1, 2003 | 08:10 PM
Kamin's Avatar
Default Re: Oil light on. B16. HELP! (poison)
do NOT DRIVE THE CAR till you get this fixed.
check the oilpan for dents, if there arent any you may have to remove the pan and inspect the pickup or pump
itzyaboyzeem03
Jul 1, 2016 04:40 PM
RIPPO
Dec 22, 2005 07:25 AM
Asway
Nov 29, 2005 02:45 PM
Roi
22
Nov 17, 2005 10:01 PM
ultra efro
Oct 25, 2003 06:01 PM
