f22b1 into ek- what axles?
i plan on swapping a 96 f22b1 into an ek. what axles will i need to use? i can't afford aftermarket ones, so i need to figure out how to rig some up. i have the stock accord axles, can i do anything with those?
Re: f22b1 into ek- what axles? (civicdxtyper)
I'm not a hundred percent sure, but I believe this to be the same as the h22 swap. In which case you would just need the 90-93 integra axles and the same for the shift linkage. But again, I am not a hundred percent sure on this. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper »</TD></TR><TR><TD CLASS="quote">thanks for the info . can anyone confirm this for sure?</TD></TR></TABLE>
Can someone confirm this? My cousin and I might do a f22b1 (96 accord EX) into and EG Sedan. We have the ECU and Tranny as well as axles from the Accord. All we need are mounts, linkage, and axles.
Re: f22b1 into ek- what axles? (macho-camacho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macho-camacho »</TD></TR><TR><TD CLASS="quote">
Can someone confirm this? My cousin and I might do a f22b1 (96 accord EX) into and EG Sedan. We have the ECU and Tranny as well as axles from the Accord. All we need are mounts, linkage, and axles.</TD></TR></TABLE>90 -93 axles for eg not sure on ek
Hey, I will be doing the same thing this summer in a 94 DX. Glad to hear someone else is giving it a shot.
Check out the following, hope this helps some.
Also, Newman has a post re: axles.
https://honda-tech.com/zerothread?id=487983
SoySauc3 H22atch
11-16-2005 08:52 AM
