Radiator hoses for b18c1 in EK?
Which hoses did you use? I'm about to pull out the d16y7, and the stock D series radiator hoses look quite a bit smaller then the hoses on the GSR engine. Im thinking I either need to force the D series hoses onto the b18, or get custom hoses?
Eventually Im planning on a del sol dual core radiator, so I will just keep the GSR hoses anyway, I assume they should fit that radiator fine.
Re: Radiator hoses for b18c1 in EK? (HXMan)
Del sol vtec upper and lower or 99-00 SI
Edit: scince i can only post 5 in 24 hours. if you slow down and read it right you will notice i said OR not del sol upper AND si lower.
either del sol Vtec or SI hoses will work with a gsr swap
Modified by 91allmotorb16 at 8:20 AM 5/4/2003
Re: Radiator hoses for b18c1 in EK? (91allmotorb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91allmotorb16 »</TD></TR><TR><TD CLASS="quote">Del sol vtec upper and lower or 99-00 SI</TD></TR></TABLE>
You are wrong. He needs gsr upper and lower hoses. How do you get del sol vtec upper and si lower? They both share the same upper and lower hoses.
ForgetMyNameX07
11-07-2008 06:29 AM
asmallsol
11-22-2003 05:02 AM
