B18C-R axle problem
Old May 5, 2003 | 01:44 PM
JDMspecEJ8's Avatar
Default B18C-R axle problem
I have a 99 model JDM B18C 98 spec R motor, and it came with 36 mm axles. I know i need either 5 lug ($1300) or an axle that will fit. My question is: will 94+ GSR or 99-00 Si axles work and how much are they? I have the complete type R changeover, which means i'll be using the 99 type R halfshaft.
Old May 5, 2003 | 02:12 PM
poison's Avatar
Default Re: B18C-R axle problem (JDMspecEJ8)
Yes. 99-00 Civic Si or 94-01 Integra axles will fit into your hubs being a 32 mm hub.
Not sure on how much they are, I would talk with Honda themsevles for a new set.
And about the half shaft. I'm not too sure the differences between the B18C-R and the US spec B series. I am pretty sure they are the same, however.
Old May 6, 2003 | 10:48 AM
yaya's Avatar
Default Re: B18C-R axle problem (poison)
does every b18c-r have 36mm?
Old May 6, 2003 | 11:32 AM
msilbernagel's Avatar
Default Re: B18C-R axle problem (yayaRl337)
I'm interested in the answer also. Anyone ever run across a table or spec sheet matching models with this specification (axle size?).
Thx,
Mark
Voodoo7
Sep 22, 2012 07:26 AM
ev13lf
Oct 30, 2008 06:59 AM
dougshatch
15
Feb 19, 2007 05:30 PM
powerofdreams8
Jun 13, 2006 07:30 AM
d15b7racer
Dec 8, 2004 06:29 PM
