Code 9
Old Jul 3, 2015 | 07:09 PM
nightscream's Avatar
Default Code 9
I have a 97 Civic Ex with a 99 B20b engine and Si trans... I used the OBD2A SOHC VTEC engine harness converted to OBD1 with a LS ECU... I can't remember what I did with the dizzy in order to get the car to run but I think I used the SOHC dizzy internals inside the B20 dizzy...
** I want the tach to work like it should, and to find a off the shelf store bought dizzy for my swap without having to rig some **** up all the time... **
REAL PLEASE HELP
Old Jul 3, 2015 | 07:53 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Code 9
You shouldn't have needed to do anything to the distributor. It sounds like you've done some damage there.
Old Jul 3, 2015 | 07:55 PM
Default Re: Code 9
The dizzy wouldn't plug up, the B20b dizzy is OBD2B... I'm running a OBD2A engine harness
Old Jul 3, 2015 | 09:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Code 9
You need to use a '96-98 Integra LS (B18B) distributor or a '97 USDM CR-V distributor. This will plug directly into the '97 Civic engine harness distributor plug without modification. You can still use the OBD-1 ECU... and you should get that ECU chipped and tuned to make it perfect.
Undergroundeg6
Honda CR-V & Element
Feb 17, 2013 06:12 AM
Vtec Civic 93
10
Aug 13, 2010 12:12 AM
EKRacer
12
Mar 17, 2004 06:59 AM
HXMan
Sep 11, 2003 02:53 PM
