Building a '99 b20b non-vtec dohc with 5speed from a CR-V from my '95 Civic EX
I'm now building a B20b non-vtec from my '95 civic ex.
I tore the block down. Hot tanked it and just a Solid Clean up on the block. Re-biulding the the head. Stainless valves, Crower Valve springs, retainers. Crower stage 2 non-vtec cams. Not sure about What induction to use at this is point. I found individual throttle body fuel injection system.. straight bolt on. Add injectors..
Now. This is the Rub..
What do I do about ECU in my '95 civic to make the '99 b20b non vtec engine and 5 speed manual trans
run and Run right???
Re: Building a '99 b20b non-vtec dohc with 5speed from a CR-V from my '95 Civic EX
What would recommend for the induction?. The engine, trans didn't come with a ECU. And its obd2, I have obd1. What ecu would I need? And how to interface with the existing obd1 wiring??
Apparently I can use my p06 ecu for non-vtec engines. Cool.!
daohgeeonethree
26
08-22-2016 05:45 PM
rashid.aslam
Engine Management and Tuning
02-11-2014 05:26 PM
