Oil Cooler replacement.....help
Old Aug 25, 2015 | 05:51 PM
galognu's Avatar
Default Oil Cooler replacement.....help
So my OBDI JDM B18C broke a retainer spring on the dyno and the valve detonated the piston as well as broke the block. So I got a nice JDM B-18C but an OBDII from Japan Direct in Canada. So I've noted some differences. Besides planning to use all my peripherals, I wanted to also change over the oil cooler and waterpipe from my OBDI motor....it was pretty easy to remove with the engine out..
However, the OBDII motor only has the large threaded nipple where you would screw on the oil filter. I read one description of just removing it with groove joint pliers. That will certainly kill the threads and if I cant remove it I'm screwed....
What about getting the appropriate sized nut and lock them against each other so I can turn it counterclockwise? Or I am I just being a wuzz?
Here are some pics. You can see the threaded pipe where the oil filter would go...that's the part that has to go.
Thanks for suggestions.
Old Aug 26, 2015 | 10:48 AM
galognu's Avatar
Default Re: Oil Cooler replacement.....help
Nobody?
Got the nuts ordered from Fastenal. Also got a pipe removal tool that has a cam on the inside. One of my buddies suggested I drill a hole through it and use a metal bar to turn it...though that would destroy it.
Will see if the double nut works.
Old Aug 31, 2015 | 08:25 AM
galognu's Avatar
double nut technique worked like a charm..
I guess big pipe wrench would have worked as well.
Anyways, if anyone is interested..here's a pic.
starecase77
Honda CR-V & Element
May 5, 2014 06:39 PM
jimmy193
Aug 17, 2008 02:29 AM
brokeHonda
Jan 9, 2006 07:23 PM
LOWLIFEHATCH
14
Aug 27, 2002 02:45 AM
