EM1 steering rack!
Old Jul 20, 2015 | 05:54 PM
h22a4_EM1's Avatar
Default EM1 steering rack!
Hello I'm new on here but I searched and couldn't find my issue! But I have a 00 Em1 with a h22a4 swap.. The other day all steering was lost and the car steering wheel would grab then all of a sudden cluck and do a complete 360 without the wheels turning then catch again and only turn left!! I jacked the car and checked the tie rods only one was leaking but neither of them were broke and also with the tires off the car turned like it was suppose too along with the steering wheel not doing a complete 360 and turning both directions.... So I called a shop and they told me the steering rack might be bad.. The car doesn't have PS on it but my question is me having the H22 defer what type of rack I can put in and does this sound like a rack problem if so what all else would I might need anything h22 specific or just another si rack will work.... I'm new to this problem and this swap.. Can someone inform me.
Old Jul 20, 2015 | 09:29 PM
h22a4_EM1's Avatar
Default Re: EM1 steering rack!
Can someone answer this??
Old Jul 21, 2015 | 12:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The proper fix is to install a new/replacement steering rack and add P/S to the H22 swap. It can be done. Another thought would be to convert to an EG manual rack and rear cross member and lower control arms... assuming that your EKH mount kit will allow this. Usually, you will have to get a rear mount for an EGH mount set so that the holes and rear bracket still line up.
The worst choice is what you have already... leave a power rack un-powered and without fluid, and eventually, it will do just what it did now... again.
The rack choice has nothing to do with the H22 engine other than you will need to get a H22 P/S pump and upper high pressure hose if you intend to fix it correctly. You then need to take an original EK P/S hose and the H22 hose to a hydraulic shop and have them join the two. The rest of the P/S system works with little modification, assuming you have it. If you do not, you will need to get it from any '96-00 civic chassis.
Old Jul 21, 2015 | 01:47 PM
h22a4_EM1's Avatar
Perfect man this was very informative! So I guess I'll have to try and hook up the power steering on the car but the guy had the wrong axles on it also so It was already hard to turn for that reason so I never knew if PS was hooked up or not but I have Hasport engine mounts but I hear there axles aren't that good so I'm gonna just go Raxels but now that I know any ek rack will work I can finally start to fix it!
White_EG1
23
Apr 12, 2016 08:34 PM
na4now
Feb 7, 2006 10:46 AM
rotten
Oct 17, 2005 05:16 PM
vtec_crazy
Aug 29, 2005 07:05 PM
