Re-use JDM Harness??
So I'm sure this question has been asked before but I decided to ask anyway:
I've got a 2001 Integra LS that I'm putting a 98 JDM ITR motor in. My question is pretty straight forward. Can I re-use the JDM harness? I know there are a few plugs that are on the opposite side but I plan on taking the harness apart and re-routing everything. I know it'll be a lengthy process but I got the time.
I've done a JDM swap before in an LS and used my LS harness last time, but since I have the JDM motor out I was hoping to just use the JDM harness.
If it can't be done I'm OK with that. It means I'm just going to have to use the LS harness.
Technical Hero
Re: Re-use JDM Harness??
I mean if you take it apart and reroute I don't see why you couldn't. The only issue I foresee is if you ever have to use a USDM ECU for emissions purposes you'll need to bypass and add some sensors.
highroller54
02-13-2007 08:29 PM
