b16a/b18 block
Old Aug 18, 2015 | 02:46 PM
dylicious_eg6's Avatar
Icon4 b16a/b18 block
i currently have a b16a, but i would like to put a b18c1 block.. if i get a block and motor mount and build my head on top of that block, will it just be plug and play once i take out my old b16a block.. or is there more to it, thanks..
Old Aug 18, 2015 | 04:08 PM
D3_Fab's Avatar
Default Re: b16a/b18 block
using the search function or posting this in a tech section would get you the fastest answer. there is a thread already started with lots of feed back and multiple combinations using b16 heads on b18 blocks that can be found in a matter of seconds (I did a quick search just to make sure) as far as it being plug and play you didn't give enough info on your current setup to enable a yes or no answer
Old Aug 19, 2015 | 08:26 PM
gmcuajo1's Avatar
Already have a b16 vtec running?
A b18c block should be plug & play, easy. Maybe need to do some minor changes, but yes as you already have vtec b16 it should be easy.
But, search.
Old Aug 19, 2015 | 10:54 PM
But, search.
Yes I currently have a b16a vtec. Gonna buy a Ls b18 block. Just wanna know everything i need. To do the swap. Will my b16 water pump and timing belt work fine on it. And do I also need a ls/vtec conversion kit for my ls block if it is non-vtec.
Old Aug 20, 2015 | 02:07 PM
KPDSM's Avatar
Yes to conversion kit.
Old Aug 20, 2015 | 08:23 PM
obviously I wouldn't need it if it's b18c gsr block so I'll be good for that
Old Aug 21, 2015 | 02:51 AM
KPDSM's Avatar
I always forget, but the timing belt thing AFAIK is related to which water pump you use.
Double check on the search, I'm at work right now ha.
I think it goes LS water pump LS timing belt GSR water pump gsr timing belt.
Old Sep 25, 2015 | 09:43 AM
I've looked many times. Only finding **** on the pulley bolt. Not getting What I want. So I need some help. Can my crank come out with out taking my flywheel off or do I need to take the flywheel off in order for it to come out
Old Sep 25, 2015 | 11:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The flywheel must come off because you cannot get to the rear main seal plate bolts with it still attached to the crank.
xDicktonesx
Aug 6, 2005 09:04 AM
LSEGHATCH
Mar 2, 2005 02:46 PM
Blk95GSR
May 29, 2003 04:59 PM
MUGENTYPER
Mar 16, 2003 07:48 PM
B_CRUZ!
Feb 6, 2002 10:06 AM
