OBD2 SOHC ZC non-vtec into eg/del sol?
Old 07-29-2015, 12:56 AM
xchikon's Avatar
Default OBD2 SOHC ZC non-vtec into eg/del sol?
I found a relatively cheap obd2 sohc non vtec zc swap that Im looking at getting to get my del sol shell back on the road. I can't seem to find to much information on the swap though. It has an e7f 5spd transmission.
Will my stock d15 mounts and axles work with this? Shift linkage? Can I use my d15 harness (I'm assuming I'll need a jumper harness for the dizzy). It comes with an ECU but I'm not sure which one. The owner had it in an EK so they arent too much help. Also curious about if the exhaust manifold is a different length like some JDM manifolds are. It'd be nice if my exhaust would just bolt up
I'm looking for a cheap way to get my del sol back on the road. Its difficult to find information on this motor because of there being dohc, sohc vtec, and sohc non vtec. I appreciate any help. Thanks!
Contender25
12-12-2006 06:06 PM
honda etr (vw)
05-21-2005 08:46 AM
Integra_Boi
05-08-2004 07:26 AM
HybridKOOP
02-09-2004 03:04 PM
patdemps
10
08-19-2003 04:19 PM
Quick Reply: OBD2 SOHC ZC non-vtec into eg/del sol?
