D15B into a 95 DX
Technical Hero
Re: D15B into a 95 DX
Which D15B? There's about 5 of them. If its the SOHC VTEC version you'll just need to wire up VTEC solenoid and VTEC pressure switch. The rest should plug and play.
Also, the P28 ECU will dump a little too much fuel for the D15B VTEC engine. It will run, but a little on the rich side. You should look into socketing/chipping the P28 ECU and running a D15B programmed chip on it.
Awesome. Thanks for the help guys. Another question, if I boost the d15b, would I really need vtec? Would it make that much of a difference whether I have it or not?
CivicDynamo94
09-13-2011 05:04 PM
todubbled1
22
03-07-2009 07:12 AM
