OIL PROBLEM I NEED HELP!
Old Aug 5, 2015 | 06:29 AM
J.HU3ZO's Avatar
Default OIL PROBLEM I NEED HELP!
Hi there ht
So I have a 00' civic with an h23a1 block with an h22a head I recently got it running good and everything not now there is a leak coming from the dizzy, i took off the cap and I noticed the dizzy from inside was filled with oil?? I replaced the o ring from a dizzy I found in my garage and it still leaks and oil got into the dizzy again?!
Has anyone ever ran into this or know of a solution
Any opinions and advice is very helpful
Thanks guys!
Old Aug 5, 2015 | 07:11 AM
กก4drWHORE!!'s Avatar
Default Re: OIL PROBLEM I NEED HELP!
I would replace it with a new o ring instead of a used one. Also have you replaced the distributor shaft seal?
Old Aug 10, 2015 | 05:09 AM
J.HU3ZO's Avatar
Yeah that's true I actually just got a brand-new o ring seal.. And the weird thing is is that there was no shaft seal!!??
So I put one on but the thing is that there's this spacer looming thing that goes around the shaft and with that AND the seal it doesn't allow the shaft to go all the way through that it's supposed to
00siboy
Oct 17, 2011 07:25 AM
Cay-DC2
Mar 21, 2011 08:40 PM
project93hatch
Jun 3, 2010 09:28 AM
SiRndX
Aug 14, 2006 03:31 AM
