B18c4 swap problem :(
Old Nov 11, 2015 | 02:43 PM
Glyran's Avatar
Default B18c4 swap problem :(
Hey Guy's
New at this forum but not new in the Honda world.
I have swap a b18c4 engine to My 1997 del sol and now i have big problems.
I dont have any idle and the engine's runs and hack on 1500rpm. And i think the engine's goes pretty good otherwise. Maybe not 100% good but it goes to drive.
But here is the strange problem. When i pump the brake i get the idle to 600-700 rpm. And when i take off the vaccum line to the brake servo the cars go up to 1500 rpm in idle and "hack" / goes bad there.
I have try other maps sensor, tps, electric signals.
I did have obd2a in My d16y8 engine and have now a converter from that to obd1 p28 ECU.
I run on the b18c4 Europa loom
What can the problem was
Old Nov 12, 2015 | 04:45 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: B18c4 swap problem :(
check engline lights?
using correct ecu?
do a vacuum leak test.
TPS stuck?
possible you have IACV/TPS/MAP/IAT/EVAP plugs mixed around?
Old Nov 12, 2015 | 04:51 AM
Glyran's Avatar
using correct ecu?
TPS stuck?
The yellow engine light is on :?
I have a p28 obd1 ECU, standard. Its not the best but the car Will work fine they say
I have try with another tps on a other intake and i still have no idle
Maybe, but i dont think so. I have check each cable and how it is now most be right.
Can i take some photos? Will that help in the problem searching?
Old Nov 12, 2015 | 05:07 AM
I'm not Rick!
negative on the photos.
what codes are you getting? you need to read them somehow
also you have conversion harness to obd1???
sounds like an OBD problem. obd2 distributor? hmmm
this is always the biggest headache in a swap is obd conversion stuff
Old Nov 12, 2015 | 06:29 AM
Glyran's Avatar
Okey,
It allways light yellow engine lamp. No other.
Yes, i have a obd2a - obd1 converter. I think this engine is obd2 but have obd1 plug style.
Maybe is it the distrubitor if its a obd2?
Old Nov 12, 2015 | 06:35 AM
I'm not Rick!
obd1 and bod2 distributors operate differently.
i believe crank sensor is in dizzy for obd1.
obd2 has no CS it has seperate plug in oil pump.
you can bypass and fix however. this could be your problem.
but definetly check codes. you need to know what the ecu wants
Old Nov 12, 2015 | 06:43 AM
Glyran's Avatar
Okey, that sounds like a good start.
About the engine code, how can i check what the code says? It Only light yellow
Old Nov 12, 2015 | 09:20 AM
I'm not Rick!
its the check engine light?
its usulay orange yellow.
obd2 has a port to hook up obd reader. not sure if it reads obd1 ecu.
obd1 car had 2 wires to cross to read CEL beeps
Old Nov 12, 2015 | 02:52 PM
HondaPartsHero's Avatar
Technical Hero
Read your codes like so
https://honda-tech.com/honda-civic-d...lists-1901557/
All OBD0/1/2 have the crank position sensor in the distributor. The OBD2 has a sensor called crank fluctuation sensor at the crank but the P28 doesn't look for it and won't throw a code for it.
Old Nov 12, 2015 | 09:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Who told you a computer programmed to run an engine that makes 125 HP will actually run a 170 HP engine "good" ??? This is complete BS. The OBD-1 and OBD-2 distributors have different plugs, but inside the cap, they are the same. Either with function just fine in your car.
Check your codes as Hero stated above and report back here... then maybe we can help. Also, get a P72 ECU or get your P28 chipped and then mapped for the GSR engine. That will be a much better start.
Old Nov 13, 2015 | 10:40 AM
I'm not Rick!
either ecu will work. i have had several swaps/civic/ecus. it works. it wouldnt be causing your issues nor give you any codes. your issue is an obd issue.
but using the correct ecu or basemap is best for a swap.
Glyran
Engine Machining & Assembly
Nov 13, 2015 07:01 PM
b_serious
Dec 1, 2005 08:21 PM
boostin1cam
Jul 20, 2005 05:39 PM
F120man
Dec 18, 2003 06:32 PM
