Help choosing a catalytic converter for a B18C1 with 00 GSR exhaust in an EG
Old 07-13-2015, 08:26 AM
ensignfluke's Avatar
Default Help choosing a catalytic converter for a B18C1 with 00 GSR exhaust in an EG
So I've recently moved to a state where they do inspections and require a catalytic converter, so I need to replace my test pipe soon with a proper cat. I'm also getting older, so a reduction in noise would be appreciated. The motor is a B18C1 in a 92 EG with an P72 OBD1 ECU. The exhaust manifold, A pipe, and B pipe are OEM 00 GSR parts, while the muffler is a Dynomax for a 92 EG.
I read in another post ( https://honda-tech.com/acura-integra...t-same-851964/ ) which said that a "94-99 GSR exhaust is different from 00-01. 00-01 GSR is shorter and matches up exactly with ALL other 2dr integras except for the 94-99 GSR."
So I'm just trying to confirm if a 94-95 LS, RS, GS direct fit catalytic converter from those years and models would really be a direct fit for my application.
I'm also wondering which brand makes a decent and well fitting converter. Does anyone here have any experience with any of those, including fit, noise, and how well they last? It seems like I have a choice between Magnaflow, Bosal, Catco, Walker, and Napa brand.
Also, if anyone could tell me, what is the length of a stock 94-95 LS, RS, or GS cat, because the Bosal ones seem much longer than the other Brands.
chikichimo
10-15-2011 05:33 PM
nandos91crx
08-23-2011 07:48 AM
SleepyEG
06-03-2003 10:07 AM
Downey
01-13-2002 10:31 PM
Quick Reply: Help choosing a catalytic converter for a B18C1 with 00 GSR exhaust in an EG
