CEL code 20 Canadian Civic
Old Jul 8, 2015 | 08:00 PM
Flesch11's Avatar
Icon3 CEL code 20 Canadian Civic
I did an LS swap into a 2000 Canadian Civic and it keeps throwing the CEL code 20 which is Electrical Load detector which I believe is in the fuse box of an LS Integra, but not a civic which means the computer is searching for one but it's not actually there because there isn't a spot for one. Does anyone know how to fix this? Should I be concerned?
Old Jul 10, 2015 | 07:15 AM
94dxcoupe's Avatar
Default Re: CEL code 20 Canadian Civic
I believe the Canadian models don't have the ELD unit. So if you swapped in an LS engine and US-spec LS ECU, the ECU will be throwing a CEL for ELD because the car does not have an ELD unit. Have you tried a Canadian spec ECU?
Old Jul 10, 2015 | 03:22 PM
Flesch11's Avatar
[QUOTE=94dxcoupe;50431788]I believe the Canadian models don't have the ELD unit. So if you swapped in an LS engine and US-spec LS ECU, the ECU will be throwing a CEL for ELD because the car does not have an ELD unit. Have you tried a Canadian spec ECU?
No I don't have a Canadian spec ECU
Civic2Fast
Jul 24, 2014 08:11 AM
SolScifen
May 19, 2013 11:35 AM
series3racer19
Dec 7, 2004 03:13 PM
no2unenolife
Oct 1, 2004 10:43 PM
OnePointFive
May 1, 2003 08:04 PM
