intake manifold clearance question
So I'm in the process of pretty much redoing the whole car and came across an issue I didn't do much research on prehand. So I have a f20b that I'm building for a turbo and since I have a s2 manifold from my prelude I didn't want to purchase a new one. Anyways I'm told the proportioning valve will need to be relocated. Now I have the option of replacing brake and fuel lines with OEM parts. But if relocation is required I'm going to make my own and run it inside the body. Anyone have any experience that can shed some light into my problem? Also running with a itr booster and master
Anti-GDD White Knight Simp
Re: intake manifold clearance question
Yes you should have to relocate it. I'm assuming you are using an H/F series tranny. I'm running an H swap in my EJ8 with the Skunk 2 mani and relocated mine
Good choice. There will only be a few mm of fire wall clearance. you will also need to cut off the threaded studs from the firewall
Thanks going to do a minor wire and line tuck just to clean everything up in there. Everyday a little bit of progress happens. I'm just sanding down the subframe and changing the steering rack right now.
Zackharris97
03-03-2018 08:01 AM
ACCORDinglyCG2
11
01-09-2016 08:58 AM
japspecjohn
11
03-08-2006 05:40 AM
