z6/y8 combo dizzy help
Old 05-28-2015, 11:21 AM
dfclark90's Avatar
Default z6/y8 combo dizzy help
Ok so I bought an eg with a z6 swap for dirt cheap and I want too swap it into my EF. I was looking at the motor and it's a z6 block with a p2j-5 00 head ( 2000 y8). The motor sounds like the timing is off and I noticed that the dizzy does not line up with all of the bolt holes and was only held in with one. I think its the z6 dizzy but do I need the y8. Also will the y8 dizzy match up with my EF mpfi harness if I used the obd1 plugs?
Old 05-28-2015, 05:17 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: z6/y8 combo dizzy help
You can use almost any other dizzy from 92-95 except the d16z6 and d15z1
Old 05-28-2015, 07:08 PM
dfclark90's Avatar
So it has to be obd1?
Old 05-29-2015, 03:49 AM
Technical Hero
Sorry missed that it was ef, you can use pretty much any OBD1 or 2 distributor with an adapter harness except the z6 or z1. If your plug is already using obd1 use one from a 92-95 d15b7/8
ef_hybrid
34
07-02-2013 09:41 AM
99_itr
13
12-24-2007 10:24 PM
Super Chicken
03-07-2005 06:15 PM
hondacru27
02-12-2004 02:55 PM
project dc2
12-19-2002 10:42 PM
Quick Reply: z6/y8 combo dizzy help
