****LS B18 SWAP IN 98 CIVIC *** HELP!!!!
I need to know what I can use & what I can't, for this ls swap into my 98 civic that had a d16y7
B18b motor is sitting in a EF chassis they swap will come with the following:
*engine harness
*ecu
*axles
*shift linkage
I also have solid mounts wondering if those will work for my swap?? I know single cams have a 2 post
& b series have 3 posts
I heard something about me needing the axles & a half shaft?
If the motor is already sitting in the car can I just plug & play everything??
*engine harness
*ecu
*axles
*shift linkage
Re: ****LS B18 SWAP IN 98 CIVIC *** HELP!!!!
Im doing the exact swap into my 98' haha.
This link (which is a sticky in this sub) has everything needed to know about this. Very detailed, very helpful.
https://honda-tech.com/hybrid-engine...A-%2A-1972711/
GL
GL
GL
GL
VERY MUCH APPRECTIATED! THANK YOU
