my b20z2 swap
my b20z2 swap
Well I just bought a B20z2 for my 92 cx hatch. and basically I am in need of some help/input with the swap.
As you can see in the pic there is some things that are missing, alternator, tranny, need some new injectors, and other knick knacks.
So far today I have removed the POS manifold and Intake manifold and cleaned it up a bit.
Going to need:
B series hydro tranny
integra shift linkage
obd1 dizzy
alternator
starter
injectors
OBD2 to OBD1 help?
So basically any help would be greatly appreciated! thanks
Modified by integraca at 5:32 PM 5/6/2006
Going to need:
obd1 dizzy
alternator
starter
injectors
OBD2 to OBD1 help?
dood, alternator and starter, go to a parts store and itll be like 170 total. teger linkages go 100bux all dy on ebay. injectors, bahhh, 15bux here, ls dizzy, i sold mine for 60 bux, and a polished one i had went for 75. tranny maybe 300-500, gsr, ls, b16.trannys, not type rs
for the harness if you are using ODB2 componets get a +96+ LS harness if you plan on using OBD1 componets get a 94-95 LS harness.
componets = dizzy, alt, injectors
gl
* it doesn't matter if you choose OBD 1 or 2 componets they should not affect performance, just use what ever you can get cheaper*
gl
Re: (r1de4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1de4life »</TD></TR><TR><TD CLASS="quote">or u can just use ur civic harness</TD></TR></TABLE>
if u use the civic harness you will have to modify the O2 wires,i believe the cx doesn't have a fourdues wire O2. the LS
Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">
if u use the civic harness you will have to modify the O2 wires,i believe the cx doesn't have a fourdues wire O2. the LS </TD></TR></TABLE>
thats correct. best thing is just run everything obd-1
Thanks guys, I think im going to go with an OBD1 LS harness, and **** yo fancy V-tec yO. So far everything is coming together. just need tranny clutch, dizzy, starter, axles and ECU
Re: (ef8lsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8lsvtec »</TD></TR><TR><TD CLASS="quote">go b20vtec or u wont really be to happy with a b20z </TD></TR></TABLE>
really? man... I sure as expletive am.
i think youre thinking of the low compression B20B... either way, they pull hard as expletive.
Re: (raiden571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 »</TD></TR><TR><TD CLASS="quote">dood, alternator and starter, go to a parts store and itll be like 170 total. teger linkages go 100bux all dy on ebay. injectors, bahhh, 15bux here, ls dizzy, i sold mine for 60 bux, and a polished one i had went for 75. tranny maybe 300-500, gsr, ls, b16.trannys, not type rs</TD></TR></TABLE>
I want to know where you get a GSR Tranny for 300-500!!
Re: (Defile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Defile »</TD></TR><TR><TD CLASS="quote">
I want to know where you get a GSR Tranny for 300-500!!</TD></TR></TABLE>
werd
cheapest ive seen em are like $550+
werd
Yea it's a b20z much higher compression as appose to the B20b's. I'm just going to go with an obd1 integra wireing harness for the engine bay. So if anyone has any of the parts I need lemme know
grammer nawzi
Re: (nsxtasy270)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy270 »</TD></TR><TR><TD CLASS="quote">very torqey for a honda motor. massage the top end of the power band a bit and youve got a great all around motor </TD></TR></TABLE>
Massage the top end? Huh? I need a massage on my lower end. What exactly did you mean by that?
Re: (nsxtasy270)
did he just say "massage the top end?"
Re: (4sd4dr)
Well that mere 8 point higher c/r is a difference of 126hp on the b20b and 146 on the B20z. I actually use to own a 94 integra with a b20b swap and managed to pull a 14.8 pretty much stock. so im excited to see what this crv powered cx hatch is gunna do! thanks for the help guys, just got the flex plate off and the dizzy installed along with getting all the grime and crap off the block.
Re: (integraca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraca »</TD></TR><TR><TD CLASS="quote">Well that mere 8 point higher c/r is a difference of 126hp on the b20b and 146 on the B20z. I actually use to own a 94 integra with a b20b swap and managed to pull a 14.8 pretty much stock. so im excited to see what this crv powered cx hatch is gunna do! thanks for the help guys, just got the flex plate off and the dizzy installed along with getting all the grime and crap off the block. </TD></TR></TABLE>
I wasnt disputting the fact it made more power, just saying is all.
Re: (4sd4dr)
nah it's cool man, neither was I .....And yes. I know I have to change the intake manifold, or else I would have to cut a hole in my firewall for the I/M....I have an LS I/M on it's way
Re: (integraca)
hey there, new to THIS forum, but longtime reader. i'm also doing B20 swap into 92VX. what engine mounts are you going to use? i am under the impression that i need to get a few gen3 teggy mounts.
Re: (integraca)
I agree you don't need vtec to have fun w/ a B20z2... just toss in some crower cams and go. I have a B20z2 + GSR tranny swap for sale BTW
https://honda-tech.com/zerothread?id=1568218
