Mount problems with B18C1 into EK
Old Apr 27, 2006 | 06:22 AM
beak's Avatar
Default Mount problems with B18C1 into EK
I just yanked the D16Y7, and dropped in the B18C1.
I was following this page:
http://www.phear7imports.net/trey/6gen/
He doesn't say anything about the lower tranny mount. I have a GSR tranny. Which mount would I use? I assume GSR? My old lower tranny mount doesn't fit onto the new GSR tranny.
Also, I bought the "Driver side mount bracket from the 99-00 Si: 11910-P30-000 $41.03". I just remove the timing belt cover, and put on the new bracket, and reuse the old mount?
Thanks!
Old Apr 27, 2006 | 10:13 AM
PLAN:B's Avatar
Default Re: Mount problems with B18C1 into EK (beak)
the old gsr mount wont fit with the b16 bracket
Old Apr 29, 2006 | 08:29 PM
robspec's Avatar
you also need the rear l braket from a 99 si
Old Apr 30, 2006 | 06:24 PM
jdmcars.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beak &raquo;</TD></TR><TR><TD CLASS="quote">
Use the front trans mount bracket from the GSR. OR 99 Si, etc.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beak &raquo;</TD></TR><TR><TD CLASS="quote">Also, I bought the "Driver side mount bracket from the 99-00 Si: 11910-P30-000 $41.03". I just remove the timing belt cover, and put on the new bracket, and reuse the old mount? </TD></TR></TABLE>
Correct. The bracket is held on with 3 bolts, one of which is behind the timing belt cover. Then you will re-use your factory Civic mount -or do some sort of upgrade mount kit to get rid of those stock mounts....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robspec &raquo;</TD></TR><TR><TD CLASS="quote">you also need the rear l braket from a 99 si </TD></TR></TABLE>
That would be the rear transmission bracket which he is speaking of, and correct, this is needed as well.
Old May 10, 2006 | 06:04 AM
Trey's Avatar
25 Year Member
Default Re: Mount problems with B18C1 into EK (jdmcars.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">He doesn't say anything about the lower tranny mount. I have a GSR tranny. Which mount would I use? I assume GSR? My old lower tranny mount doesn't fit onto the new GSR tranny.
Everything is detailed in the link you provided. You have to read the entire page.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6gen swap guide &raquo;</TD></TR><TR><TD CLASS="quote">Mounts
Driver side- Use the mount bracket I mentioned above. This piece bolts to the block below the cam gears. reuse the civic studs. Also, use all other civic parts at this location. (picture)
Rear tranny- Use the rear upper tranny bracket I mentioned above. Use the stock civic rubber mount. (picture)
AC Bracket- Use the ac bracket I mentioned above and reuse the civic stud and rubber mount. Integra piece is similar but won't work. (picture)
Front tranny bracket- Use integra piece on the tranny but civic stud and rubber mount. Integra stud and rubber looks the same but won't work.
Upper tranny mount- Use all the civic pieces.
be18see1
Jul 31, 2007 06:24 AM
THugluv423
Mar 23, 2005 07:55 PM
u2civic1
Jul 4, 2004 01:13 PM
GReddy SI
Dec 22, 2002 08:27 PM
