2000 B16B into 99ex wiring help please...
Does anyone have any information regarding the wiring for this swap...I heard that all i need is a harness from a 99-00 Si and its completely plug n play. Need someone to back this up. Any info would be helpful. I've searched nothing comes up.
Thanks in advance
Thanks in advance
DYNO-PRO
Location: SoCal I.E 909, CA, where we innovate not immitate
Re: 2000 B16B into 99ex wiring help please... (ProjectNoob)
Your harness that you already have is absolutely perfect you will might just have to extend a few wires . We do this everyday please call if you need help
Re: 2000 B16B into 99ex wiring help please... (HOOKUPS)
Awsome i will give you a call on Monday to find out more. Who should i ask for? What about the axels and shift linkage that comes with the swap...most of my research was on the ITR engine swap rather than CTR but switched directions. I know that the ITR axels have a 36mm hub and mu civic has 32mm will i run into the same problem with the CTR axels? Hope you understand what i wrote.
You cannot use stock D series axles and mounts on a B swap (sans the driver side top mount).
Click the link in my sig for help. It's mostly for the 96-98 EK swap but does have some 99-00 wiring info and the correct mount info....
Re: 2000 B16B into 99ex wiring help please... (Trey)
Thanks for the replys...I didnt think i would use my stock axels. I have been to that site many times and have read and re-read the write up many times.
MysteryWagon
07-05-2001 05:54 AM
