engine harness??
Old May 6, 2006 | 03:59 PM
fiftee_su's Avatar
Default engine harness??
I have a 99 si motor into a 94 del sol
could i use an obd1 ls or gsr engine harness and just plug it into the del sol's harness that is already on the vehicle?
problem I'm having is that engine will not rotate.
Old May 7, 2006 | 07:32 AM
RaceCarRyne's Avatar
Default Re: engine harness?? (fiftee_su)
always use the harness that came out of the car
Old May 7, 2006 | 10:10 AM
egsleepercivic's Avatar
what do mean by "will not rotate?
how are you setup now?
Old May 7, 2006 | 02:02 PM
fiftee_su's Avatar
Default Re: (egsleepercivic)
engine will not rotate meaning starter will not function and do its job..
i have a 99si complete drop out into a 94 delsol. I do not have the del sol engine harness...i have a ls and gsr obd1 engine harness. could i use any of these along with the delsol's harness that is attached to the vehicle?..or should i go to a salvage yard and find a 94 del sol engine harness??...ive checked the starter in many ways and could not get it to rotate....to the best of my knowledge starter problems equals battery ground and starter itself right? nothing else deals with the starter problem is there??what fuses or relays could i check?? i know its not the clutch sensor for sure. so lost and tempted to give up.....thanx in advance for any help
Old May 10, 2006 | 05:55 AM
Trey's Avatar
25 Year Member
Default Re: engine harness?? (DC2jdmIntegra)
He cannot use a 99 Si engine harness in the 94 del Sol.
He can use the 94 del Sol harness and add what he needs or he can use any Vtec teg harness and it will plug in at the shock tower.
*pic by Katman
gzes
Dec 23, 2012 01:09 PM
nomotorsol
Jun 18, 2004 11:42 AM
oem
Jun 10, 2003 01:35 PM
