B18C4 into CRX
Old 05-10-2006, 10:43 PM
franckcrx's Avatar
Default B18C4 into CRX
Hi,
I am from France.
I have a 1990 CRX (with D16, 130hp, the engine blew off ), and i got what you 've called a GSR in USA. Mine is a B18C4, with S9B LSD Tranny.
I have the all engine bay for the swap, including ECU, wiring, injectors...
I used the 'search button' for that swap, found this http://www.norcalcrx.org/dropp...p.htm
but i need more info on wiring, as i have everything with the engine, do i need jump wire ?
Old 05-11-2006, 12:16 AM
Say Hello's Avatar
Default Re: B18C4 into CRX (franckcrx)
You can get a harness conversion that plugs up.
Check out hcpracing.com or hasport.com or might be ha-sport.com.
You need a hydrolic to cable conversion for the trans.
Also the mount kit.....
and a wiring conversion from obd1 to obd0 to make it easy.
I use to know about this stuff but havent done or looked at obd1 or obd2 to obd0 swap in a while.
Old 05-11-2006, 02:34 AM
franckcrx's Avatar
Default Re: B18C4 into CRX (Spoon AP1)
Thanks for your help.
Why should i use a harness, as i have the ECU with it ? that is the mistery for me at the moment
Old 05-11-2006, 07:51 PM
Say Hello's Avatar
because if its a 96+ its obd2
if its an obd1 too
so you need a harness adapter because you are installing it in an obd0 car
Old 05-11-2006, 09:50 PM
Taristin's Avatar
Did they have obd1/2/etc in France?
Old 05-11-2006, 11:31 PM
franckcrx's Avatar
Default Re: (Taristin)
Yes we did have obd norms.
I tought we had to use harness when the ecu had a different obd than the engine. In my case i have the ecu, and everything with it (alternator, ignition, injectors, EACV...), the all wiring
So the harness is for what use ? i cannot understand. My car is like à 98 model so, except from the shape, no ?
Sorry to be a pain , but i only want to understand
thehatch97
10-15-2009 02:17 PM
Raoul
04-09-2009 10:15 PM
gabrielle
12-18-2006 12:15 PM
soundman
10
11-14-2003 07:59 PM
Ryan C
06-29-2003 11:41 AM
Quick Reply: B18C4 into CRX
