Throttle cable???
Old May 9, 2006 | 08:21 PM
Civic Hybrid's Avatar
Default Throttle cable???
I have a b16a and just bought an ITR intake manifold. I was wondering if the throttle cable on the b16a will work with the ITR manifold or do I need to get a new cable?
Old May 9, 2006 | 08:28 PM
94hatchvx's Avatar
Default Re: Throttle cable??? (Civic Hybrid)
its should work. but you should also buy the type r throttle cable bracket. it works a lot better than the stock when you have the type r Intake Manifold. http://www.inlinefour.com they have it under OEM on the side tabs. good luck
Old May 9, 2006 | 08:42 PM
Default Re: Throttle cable??? (94hatchvx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">its should work. but you should also buy the type r throttle cable bracket. it works a lot better than the stock when you have the type r Intake Manifold. http://www.inlinefour.com they have it under OEM on the side tabs. good luck
I'll check it out. thanxs
Old May 10, 2006 | 07:34 AM
anyone else......please help info needed!!!
Old May 10, 2006 | 09:49 AM
Trey's Avatar
25 Year Member
Since they are basically the same cast, you should be fine, It's not radically different like the GSR manifold.
tai....
Northeast (Sales)
May 18, 2007 04:03 PM
TurboIntegra
Jul 21, 2006 03:25 AM
THEUSED
Dec 29, 2005 08:30 PM
Autoworks
Mar 10, 2005 04:19 PM
Bnjmn
Dec 6, 2003 08:44 AM
