GSR wire swap?
GSR wire swap?
is the gsr wire harness (engine harness) pnp or does it need to be modified? 95 gsr swap in a 94 dx already wired in vtec and knock sensor. ive searched for the past hour and cant find ne thing. i dont have ne engine harness at all. thanks
Re: GSR wire swap? (FullJDMEg)
if ur putting a gsr with a gsr harness into your 94 dx then u need to switch the evap A20 wire at the ecu pin to the A11 which is IAB, and then wire the evap wire from the shock tower connector to the ecu.
then u just need to add wires for vtec, vtec pressure, and knock sensor from the shock tower connector to the ecu.
