TRANNY ???
Old May 7, 2006 | 10:53 PM
juniestyle's Avatar
Default TRANNY ???
I just did a motor swap from a 99 civc si to a 2000 gsr!!! After i put the gsr motor and tranny i couldnt put the shifter into 3rd and 4th gear!!! It would just grind...and if i push the the shifter harder into 3rd and 4th gear it would grind even louder!!! My question is... is the syncros bad or is it the shift linkage??? I am using the shift linkage off of the 99 civic si on the 2000 gsr...so do i need to replace the shift linkage too 2000 gsr??? HELP!!!
Old May 8, 2006 | 08:34 AM
juniestyle's Avatar
Default Re: TRANNY ??? (juniestyle)
help!!
Old May 8, 2006 | 09:02 AM
dynamo's Avatar
Sounds like you got a bad tranny. Shift linkage should not matter - the only issue you may encounter is the linkage rubbing against the o2 sensor, but that wouldn't prevent you from shifting smoothly.
Old May 8, 2006 | 11:13 AM
juniestyle's Avatar
Default Re: TRANNY ??? (dynamo)
what could be wrong with it???
dsd1_209
Transmission & Drivetrain
Nov 1, 2012 06:53 PM
bwfisherman09
Oct 12, 2012 05:35 PM
honcrx91si
Aug 25, 2006 08:24 PM
UrVtecIsLoud
Jul 26, 2006 07:26 PM
