quick question...answer asap.
Old May 4, 2006 | 04:56 PM
B16A3Civic*Eg's Avatar
Default quick question...answer asap.
I finally decided to do a b18 ls and turbo it. But one thing about the swap. My wiring harness i have now has vtec and all that good stuff. Can i still use it on the ls but just not use vtec? Or do i need a knew harness. And will my harness work with the ls ECU?
Old May 8, 2006 | 10:17 AM
jdmcars.com's Avatar
Default Re: quick question...answer asap. (b18*EG*Sleeper)
Your stock harness will work, if my guess is correct that you have a EG SI/EX civic and are using an OBD1 LS.
bettsbanger
Feb 2, 2009 03:07 PM
B16A3Civic*Eg
May 5, 2006 08:26 PM
gen2fanatic
11
Sep 25, 2005 05:26 PM
89JDMcrx
Nov 12, 2002 09:34 PM
