obd2 b18b swap into EK CEL code 41 help!!!
i have been driving around with the check engine light on for awhile now. i did a 98 b18b into my 00 EK with an obd2b to obd2a jumper harness. after the swap i jump the code and got code 41 one which i think is the heated o2 sensor circuit. is this hurting my performance? does anyone know how to get rid of the code without converting back to obd1? Please help.
Re: obd2 b18b swap into EK CEL code 41 help!!! (4cylsturbo)
I just pulled codes and the ecu was only throwing a code 41. Just curious if you fixed the problem or figured out a way to eliminate the code?
93CharcoalHatch
20
04-20-2006 05:42 AM
boostedcivichatchbacksi
09-30-2004 05:09 PM
