B16a2 into 96 Civic Dx have questions..Please
Old 05-11-2006, 11:14 AM
zaxfire's Avatar
Default B16a2 into 96 Civic Dx have questions..Please
Hi..I have decided to put a B16a2 into my 96 Civic Dx..I am in desperate need of what I need to purchase to make this work...Like a parts list..If someone has done this before and bought the parts to do it..I beg you please list them for me so I can make sure I order everything so I can get the motor and Drop it in..I am so confused with all the posts that I have read..I wish someone would just email me or post in this topic..I want to be able to go out and order everything that way I can do it right the first time...Here is what I have come up with so far...
B16a2 engine swap
Rear mount from a 99-00 Si
Axles--But which model axles???
Odb2 to Odb1 harness for the Ecu
After that I draw a blank...Someone please help me..I have searched for hours...
I have a digital camera when it comes time to do this I will post pictures..I just need someone that has done it before to give me some guidance..Don't want to beg, But I am..Thanks in advance...David
Old 05-11-2006, 01:59 PM
1rude2l's Avatar
sticky on top everything you need to know
Old 05-11-2006, 04:28 PM
EKhatch84's Avatar
Default Re: B16a2 into 96 Civic Dx have questions..Please (zaxfire)
hey i did the swap but with a gsr head. so u will need
axles
half shaft
hydro tranny
b16 motor
i would do a jumper harness from obd2 to obd1
then a obd1 vtec ecu p28,pr3,p72gsr
i changed my engine bay harness to 99-00 si so its ready for vtec
u can use a obd2 vtec dizzy gsr or b16
shift linkage 94+ integra or 99-00 si
i know i dont have everything listed but will update
i hope this helps u.
Old 05-11-2006, 04:33 PM
Deano_D aka
Default Re: B16a2 into 96 Civic Dx have questions..Please (Ekhatch84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekhatch84 &raquo;</TD></TR><TR><TD CLASS="quote">hey i did the swap but with a gsr head. so u will need
axles
half shaft
hydro tranny
b16 motor
i hope this helps u.</TD></TR></TABLE>
I would get a 96-98 ex harness instead since its obd2a like the car is, the 99-00 is obd2b
Modified by Deano_D at 2:42 AM 5/12/2006
Old 05-11-2006, 05:04 PM
EKhatch84's Avatar
Default Re: B16a2 into 96 Civic Dx have questions..Please (Deano_D)
yeah u are right i forgot i change my dash harness 2 si also
Old 05-11-2006, 05:51 PM
zaxfire's Avatar
Ok the the info you guys are giving me is what I am looking for..Just to make sure that all this will work with the engine I am looking at..A Jdm 92-95 B16 with the Hydro tranny..Everything you guys have told me will work with this engine setup...Right..I Forgot all about the 96-98 Ex Engine harness. It should be plug and play right...Keep the info coming I am like a sponge..Soaking it in...
Old 05-12-2006, 05:08 AM
Trey's Avatar
Default Re: (zaxfire)
Click the EK Swap link in my sig.... It's also in the Engine swap guide that is stickied in this forum
Old 05-13-2006, 05:48 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: (Trey)
If you need the VTEC subharness let me know I have the cheapest around
Old 05-16-2006, 05:01 AM
zaxfire's Avatar
Well right now I am looking for a 96-98 Honda Civic ex engine wiring harness..That is gonna be the first part I am gonna purchase..Tell me what your harness can do for my particular swap and I will buy one from ya...Post me some particulars...Thanks
Old 05-16-2006, 09:53 AM
Trey's Avatar
I paid $100 for my EX harness. I doubt he can beat that.
Old 05-18-2006, 02:48 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zaxfire &raquo;</TD></TR><TR><TD CLASS="quote">.I Forgot all about the 96-98 Ex Engine harness. It should be plug and play right...</TD></TR></TABLE>
Not quite.
You wont need to wire up the vtec solenoid, vtec oil pressure switch, or knock senoser,
but
you will need to adapt the wiring harness to fit the obd1 motor. This will include changing the plugs for the distributor, injectors, and alternator.
Old 05-19-2006, 08:32 AM
zaxfire's Avatar
So you mean I will have to use the plugs that come with my motor swap..Plugs for the Distributor, Injectors and alternator..The Female ends..Those are the only 3??? That dosen't sound that hard..Anything else I need to be aware of..Man thanks for the input..
Old 05-19-2006, 09:17 AM
Slopoke's Avatar
Yeah, thats what I mean.
Those are the only 3 I can think of, if your using the ex harness.
Old 01-23-2007, 03:26 AM
speedborn's Avatar
Default Re: (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey &raquo;</TD></TR><TR><TD CLASS="quote">Click the EK Swap link in my sig.... It's also in the Engine swap guide that is stickied in this forum </TD></TR></TABLE>
Trey, I´ve clicked on the guide you said but the pictures are missing, is there any way you can make a new post with those pictures it'll be very useful for me, since I'm intalling a B16A2 from a '99 civic si into a '96 Civic hatchback with a D16Y7 motor.
Thanks
EKcivicEK
07-27-2008 10:51 AM
civic542
11-05-2007 01:15 PM
Binar
04-07-2005 11:56 AM
MADEinJAPAN
03-11-2003 07:09 PM
Quick Reply: B16a2 into 96 Civic Dx have questions..Please
