ob2 -obd1 distributor and conversion harness ?????'s
I have a h22 swap and I have a obd2 distributor on my motor. My harness is obd2 and I have a p28 with stepdown I want to get chipped and tuned... I was told that you cannot use a obd2 distributor with a obd1 ecu.. If this is so, why??? also I have read and read and tried to figure out how to wire in my obd1 distributor but I cannot get a simple explanation!!!
Re: ob2 -obd1 distributor and conversion harness ?????'s (Oclooc)
OBD2 dizzy with work perfectly with an OBD1 ecu..
OBD0 CANNOT work with a OBD1 ecu...
Also i do tunning and chipping...
http://www.racingchips.com
You can run the OBD2 distributor with an OBD1 ecu. There are no issues with that. The OBD0 distributor will not work with the OBD1 or OBD2 ecu and vice versa.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsirvtec »</TD></TR><TR><TD CLASS="quote">
http://www.racingchips.com</TD></TR></TABLE>
How about that customer that you ripped off for the free Crome software you sent him? Never sent his money back did you?
Re: ob2 -obd1 distributor and conversion harness ?????'s (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">You can run the OBD2 distributor with an OBD1 ecu. There are no issues with that. The OBD0 distributor will not work with the OBD1 or OBD2 ecu and vice versa.
How about that customer that you ripped off for the free Crome software you sent him? Never sent his money back did you?</TD></TR></TABLE>
wow!!!!! so do we get an answer?????????????
DIYMIKE
02-23-2007 09:06 PM
jolt-tsp
04-30-2005 12:46 PM
