swaping a b16 into my ek what mounts do i need..
i have a 97 civic cx hatch
and i am buying a b16 out of a 99 civic si
the motor doesnt come with wiring harness or mounts
i already have the wiring harnes and i have a Rear Tranny mount from a 99 si and a Driver side mount bracket from a 99 si what else do i need to make the swap work
Re: swaping a b16 into my ek what mounts do i need.. (Civic97s)
oh and the motor is usdm and my car is usdm so im guessing i need more si mounts i just dont know what ones
you need all the SI mounts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic97s »</TD></TR><TR><TD CLASS="quote">oh and the motor is usdm and my car is usdm so im guessing i need more si mounts i just dont know what ones</TD></TR></TABLE>
well your gonna need ALL of them. and the linkage from an 99-00 si also.
Re: swaping a b16 into my ek what mounts do i need.. (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">you need all the SI mounts.</TD></TR></TABLE>
damn just think, an SI DOES have the same engine bay as a hatch
Re: swaping a b16 into my ek what mounts do i need.. (The Secks)
what others do i need
i already have a Rear Tranny mount and a Driver side mount bracket
you need the rest of them.
if I have to name them out to you then you have no business doing a swap.
well it would be nice if you would
and im better hands on then knowlege and have some friends helping with the swap
the only reason i need them listed out is because i have everything to do a b16b swap from hmotorsonline.com but since that has changed dues to ny inspection and emmissions i am getting a usdm b16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic97s »</TD></TR><TR><TD CLASS="quote">what others do i need
i already have a Rear Tranny mount and a Driver side mount bracket </TD></TR></TABLE>
well there is four mounts total. so go find the rest. and quit asking *** bag questions.
if you have everything to do a b16b then use those mounts.
well i only have 2 mounts
the others would be included with the motor from hmotors
and the ecu and everything
i feel like I keep taking you one step forward and then you take yourself 3 steps back.
Honda-Tech User
Give the guy a break. Im sure you didnt know everything when you first bought your civic or integra. Got to learn somewhere. Right?
Re: swaping a b16 into my ek what mounts do i need.. (10seconds)
yeah, its called SEARCH
Man there is a bunch of mis-information in here.
No do not use the 99-00 si ecu with your 97 car.
No do not use Hasport mounts.
Click the link in my sig for more info on the swap...
Re: swaping a b16 into my ek what mounts do i need.. (Trey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey »</TD></TR><TR><TD CLASS="quote">Man there is a bunch of mis-information in here.
Click the link in my sig for more info on the swap... </TD></TR></TABLE>
99-00 SI Ecu should be just fine w/ an obd2a to obd2b jumper harness. Although I don't know about any immoblizer **** that mgiht be on the SI.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey »</TD></TR><TR><TD CLASS="quote">Might as well get an OBDI harness converter and a Chipped P28. </TD></TR></TABLE>
For sure.
For sure.
myEK=slow
13
07-13-2006 09:45 PM
99BlackHatchSiR
03-11-2006 06:36 PM
jaydm ferio
10-26-2004 08:06 PM
