help code 22
Old May 3, 2006 | 12:45 PM
9WON4's Avatar
Default help code 22
VtecVillan Wrote: I'd like to add that there is a simple wiring method that you can do if you are using a pressure-less solenoid with an ECU that looks for the pressure switch sensor. If anyone runs into this problem and needs to know how to wire around it without changing the solenoid, just let me know.
does ANYONE know how to Freakin do this?? thanks!! and someone get Vtec Villan....thanks guys!!
Old May 3, 2006 | 09:22 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: help code 22 (kidkanedtx)
Depending what ecu you are using if its a chipped ecu you can have someone turn off the vtec pressure check
Old Jun 2, 2006 | 06:11 PM
digital sol's Avatar
Default Re: help code 22 (HOOKUPS)
i grounded my vtec pressure switch wire', if my memory serves its orange/white
just ground it am your good to go'
prime-R
16
Apr 11, 2009 05:33 PM
ToeJam
Apr 3, 2008 06:01 PM
nutball72
Aug 26, 2006 10:54 AM
inline4
Jul 27, 2006 03:05 AM
lshatch92
Mar 27, 2006 10:04 AM
