EK9 LSD in a DC2
Old May 1, 2006 | 12:15 PM
ckyguy's Avatar
Default EK9 LSD in a DC2
I found a good deal on an EK9 LSD and was wondering if I need to replace any bearings to make it fit and if the outer ring gear is a different ratio on the EK9 than the DC2. Any info on this would be great.
Old May 1, 2006 | 04:54 PM
I makes it RAIN's Avatar
Default Re: EK9 LSD in a DC2 (ckyguy)
http://www.ff-squad.com/tech/temp/Bgears.htm Ratios for ya.
Old May 5, 2006 | 07:42 AM
Salami's Avatar
I am not postive but I believe you will need a new differential gear. The ratios are the same but I believe the bolt pattern diameter is different.
wo2m
Aug 19, 2013 08:14 PM
kuki
Jan 12, 2006 10:38 AM
Mo_Spec
May 17, 2005 06:02 PM
Fink2iCe
Aug 11, 2004 02:26 PM
ls95hatch
May 19, 2004 02:06 PM
