Identify these H22 & D16 Sensors
A. Atttactched to bracket on the H22 fuel rail. Vaccuum line from it runs to the fuel pressure regulator.
B. I know this is one of the EGR sensors (H22) but which?
C. Sensor on black box under the H22 intake manifold.
D. Right side of H22 intake manifold.
E. Air filter container of the D16.
F. Sesnor below air intake tube with one vaccumm line (D16).
H22 is going in this dirty pig.
Re: Identify these H22 & D16 Sensors (ScottEK)
Hey dude, I can help u out with the h22 ones but i've never touched a d16.
A. That's a sensor only on the JDM engines i'm told, helps cold starts by providing vacuum to the manifold till it starts er something. Everyone told me you dont need it, so I wouldn't woryy about it.
B. That's the EGR Valve. Almost everyone doesn't use the EGR for h22 swaps and you can buy or make a block off plate for that.
C. I believe that to be either the intake control solenoid valve of the intake air bypass valve, dont quite remember it was a long time ago for me.
D. I think thats the Intake air temperature sensor, (someone correct me if I'm wrong.)
Hope this helps u out a bit. Good luck.
A. throw it away for ease of install.
B. Egr Lift Valve
C. Intake Air Bypass (IAB)
D. Intake Air Temperature (IAT)
E. Intake Air Temperature (IAT)
F. Evaporative Purge Control Solenoid
B. Egr Lift Valve
Re: (v4lu3s)
man i think i'm trying to figure out this same questions. the pics are dead on this post is there anyway we can get them reposted .
thanks
gib
thanks
gib
