LSD trans???
Old Apr 25, 2006 | 07:34 AM
athbaseball23's Avatar
Default LSD trans???
Is it worth the $300 for the lsd trans from hmo? Or should i put that money towards an itr header or cluth flywheel kit? What does the LSD trans exactly do that is different from the regular?
Old Apr 25, 2006 | 08:19 AM
Honda Bull's Avatar
Default Re: LSD trans??? (athbaseball23)
A limited slip differential is a device that allows for better cornering, braking, and acceleration. The Honda one holds up a lot more to abuse versus their open-differential. It's definately worth the $300... it just depends on what you want to do. Everything you mentioned, LSD, header, and clutch are all good buys. Just depends on how YOU want to spend YOUR money.
Old Apr 25, 2006 | 12:29 PM
jdmcars.com's Avatar
Default Re: LSD trans??? (Honda Bull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Bull &raquo;</TD></TR><TR><TD CLASS="quote">A limited slip differential is a device that allows for better cornering, braking, and acceleration. The Honda one holds up a lot more to abuse versus their open-differential. It's definately worth the $300... it just depends on what you want to do. Everything you mentioned, LSD, header, and clutch are all good buys. Just depends on how YOU want to spend YOUR money. </TD></TR></TABLE>
Couldn't be put better
Aodhan
Oct 8, 2007 09:35 AM
lovey408
21
Sep 6, 2007 07:35 PM
clemsoncb7
Apr 2, 2007 07:46 AM
athbaseball23
15
Apr 26, 2006 10:01 AM
june
Jun 24, 2005 10:13 PM
