type r or gsr
Old May 8, 2006 | 10:20 PM
i like my eg's Avatar
Default type r or gsr
ok i have a eg and i dont know if i should put in a type r or an gsr in it some people say that the type r is over rated and the gsr is just as good but i dont know witch one i better for me and witch one i could get the most out of help me
Old May 9, 2006 | 05:47 AM
StorminMatt's Avatar
Default Re: type r or gsr (i like my eg)
It all depends. One factor to consider is cost. And the price difference between a GSR and ITR is not THAT great if you pay retail. However, you can probably find a GSR for MUCH less if you actually look around. Then there is power output. The ITR does put out quite a bit more. And it IS true that getting the GSR to put out ITR power WILL cost more than the price difference between the two. But if you plan to do an extreme build, then a GSR might be a better idea, since there is no point in paying extra for stuff you plan to upgrade further anyway. So here's how I see it: if you just want to drop in a motor with good power and forget about it, go ITR. But if you can either get a GSR cheap or plan an extreme build, go GSR.
BLeSR
76
Dec 16, 2009 01:58 PM
JDM_Spec
Feb 27, 2005 04:41 PM
55rezntogofst
Dec 11, 2004 12:46 PM
vtec crx
Oct 11, 2002 09:09 AM
BrandonClaps
May 17, 2002 08:42 AM
