Ok here goes finally finacially stable SWAP help
OK guys finally financially swap capable...Wanting to do a B20 Vtec swap into my EG - plans for turbo B20 Vtec later.....What do i Initially need..i.e. what linkage, Cv joints...what head makes more power the b16 or GSR heads?...already have a OBD1 GSR tranny with Kaaz LSD....little help would be simply marvelous.
Re: Ok here goes finally finacially stable SWAP help (klownd)
a b16 has smaller combustion chambers therefore will raise ur compression a little bit. For any B series swap (hydrolic tranny anyways) you will need b seres mounts, a b series shift linkage, b sereis axles and b series intermediate (halfshaft). If your planning to boost later without building the motor, look moreso into using an LS bottom end.
you dont have a neighborhood friendly honda tuning shop?!?!
well if you want boost... personally i would go ls cheeper engine starts with lower compresion or really just keep your d and run at like 10lbs.. when it blows pick another one up for 150-200 bucks
Re: Ok here goes finally finacially stable SWAP help (CBEengineering)
My plans are actually to do as follows i really just need to know what i might encounter other than the obvious head conversion (oil lines) that i need to replace as far as the B20 with more than likely a GSR head.
1. Install stock B20 vtec
2. Gather parts to completely build Motor (should take less than 6 months (sleeves pistons rods valves cams crank bolt ons everything)
3. disassemble and send block to shop to be sleeved stroked etc.
4 reassemble motor
5. Baby the hell out of it for 1500 miles or so...
6. Run it a few passes to see what ive created and start my K24 vtec del sol project (for my wife..heheh....gonna pay to have this done i think.)
4 reassemble motor
Anthony Lorenz
09-14-2019 09:31 AM
91CrxMann
34
05-15-2015 05:15 AM
EFR
04-06-2011 11:04 AM
<3 My Honda(s)
16
06-09-2009 10:09 AM
single cam vtecn
13
09-30-2003 09:45 AM
