H22A MAP Sensor Question
Old Feb 27, 2002 | 06:05 AM
boosted1993fd's Avatar
Default H22A MAP Sensor Question
I have a question about the MAP sensor on my JDM H22a. I'm installing this swap into a `99 Integra and I was wondering where I should plug the MAP sensor into...can't seem to figure out where it should go. Thanks for any help.
Old Feb 27, 2002 | 12:42 PM
H22ACiViC's Avatar
New User
Default Re: H22A MAP Sensor Question (Interlude)
what u mean on where to plug it in at ?? but a haynes manual and u can see the vac line goes into it and then on my jdm h22a i mounted it on the back firewall i have a civic though and my stock d series motor has the map sensor mounted on the TB so i used the jdm map and mounted there works great .....
Old Feb 27, 2002 | 04:19 PM
H22AMedina's Avatar
maybe this will help
http://members9.clubphoto.com/alejan...ner-5078.phtml
I'll take some better pics if you can't find what your looking for
congrats on the hybrid
Old Feb 27, 2002 | 04:38 PM
Default Re: H22A MAP Sensor Question (H22AMedina)
I was talking about the wiring specifically...I have the vacuum lines hooked up. There is a plug that goes to it and I can't seem to find anything that plugs into it...easy fix to this? Also....H22AMedina...Thanks for the pics...if you get a chance can you take some close up pics of the intake manifold area?
Also...can I use my stock Integra cruise control system along with this swap? Just asking because the prelude cruise control runs on vacuum lines and the Integra one doesn't. If I can just use the Integra unit...I'm assuming it would be ok then to cap off the vacuum line that is supposed to go to the prelude cruise control box...sound right? Would it work this way?
Old Feb 27, 2002 | 05:31 PM
H22ACiViC's Avatar
New User
H22Medina i have a few questions i am
doing the swap this weekend been planing for awhile now just finally got
everything done... who modifyed ur wire harness ? what year is ur motor ? was
it hard to get it in there ? what ecu are u running ? is it quick ? sorry
about all the questions just curios about everything thanks alot Jesse
Old Feb 27, 2002 | 11:22 PM
chameleon's Avatar
right on the top of the TB there are two hoses, the bigger one goes to some sensor and the smaller one closer to the front of the car is the one that goes to the MAP sensor, just use a hose and plug it up from the map sensor and plug that bish up.
Old Feb 28, 2002 | 01:13 AM
Default Re: H22A MAP Sensor Question (chameleon)
Thanks everyone..I have everything taken care of for now....sunday I'll be starting it up..hopefully..i'll let you know how it goes.
Old Mar 1, 2002 | 12:23 PM
H22AMedina's Avatar
I didn't do my swap so unfortunately I can only help by pics of mine and advice from personal experience. I also have a group of guys I regularly talk to on clubsi that know a lot as well. Here is a thread that I've started to help H22A hybrids out, I'm sure how to help with your integra.. but hey any help is better than none right I do know that my cruise control does work as well. Oh and I will be putting up new detailed pics in a moment for everyone.
Old Mar 1, 2002 | 12:24 PM
H22AMedina's Avatar
Default Re: H22A MAP Sensor Question (H22ACiViC)
oh yeah.. here is the forum to help you guys with all of your questions
http://forums.clubsi.com/ubb/Forum38/HTML/003650.html
Old Mar 1, 2002 | 01:07 PM
H22AMedina's Avatar
here's more detailed pics of the motor and update on what my car looks like http://members9.clubphoto.com/alejan...ner-5078.phtml
Old Mar 1, 2002 | 05:56 PM
crap...i was going to follow some of your vacuum lines H22AMedina...and I saw that you have Hondata...so that setup wouldn't work on mine would it?
Old Mar 2, 2002 | 12:46 PM
H22AMedina's Avatar
I had the lines like that before the hondata
Old Mar 2, 2002 | 04:37 PM
Cool thanks!! Here is a pic of it from today..
Almost done...
Old Mar 2, 2002 | 05:36 PM
H22AMedina's Avatar
nice and clean just the way it should be .. good job
brian8702
Aug 10, 2010 06:59 AM
brian8702
Aug 9, 2010 10:50 PM
likwidchz
Engine Management and Tuning
Aug 21, 2008 05:53 AM
JdmCIVIC853
Apr 16, 2003 09:27 AM
