anything in specific I have to do to a B18c....
Im wondering about the mount brackets, and if thes will just pop right in to a 92 vx or do I have do get diff. engine mounts. I know all about the tune up I have to do to the engine before it goes in but just need help with the actual drop....(engine mounts) if anyone knows which engine mounts I need plz add to this. Thanx
Oh ya when I order the engine should I ask for the wiring harness or does it come with the engine.
[Modified by Redracinghart, 11:03 AM 3/3/2002]
Re: anything in specific I have to do to a B18c.... (Redracinghart)
Use all the mounts, shift linkage, and axles from a 94+ Integra and everything will drop right in.
the only real mount you can re-use from your civic mounts is the TOP tranny mount. That's it.
You need the rest of the bracket-mounts from a 94+ integra. I'm talking about the stamped steel mounts, not the rubber motor mounts -- you can reuse all of your civic's mounts that have that black rubber inside of them, unless they're damaged, you might want to look in getting a prothane mount stiffener kit.
would I ask that these be included with the swap or just get them a local junk yard?
Re: anything in specific I have to do to a B18c.... (Katman)
Hey:
Get the mounts with the engine. You are going to need to use the Integra mounts for just about everything.
On the lower front engine mounts (the one you have to mess with to change the belts), you will need the INtegra mounts on the motor, but the "half donuts" that attach to the body will need to be from your Civic.
Get the wiring harness with the motor.
Good Luck
Good Luck
Re: anything in specific I have to do to a B18c.... (LXguy)
thanks should have this in buy early april and then will show pics and a documented installation guide.
Drew Peacock
12-03-2004 03:31 PM
