Question about 310cc injectors
Old Feb 27, 2002 | 09:04 PM
lube's Avatar
Default Question about 310cc injectors
I am planning on building an ls/vtec with either JDM ITR pistons or CTR's. Now everyone says I can use the stock si ecu and injectors if I go with the JDM ITR's, but what about if I want to do the CTR's? Will I need the 310cc injectors? How big of an effect will they have on fuel mileage? What do you guys run/recommend?
PS I'll 'only' be running CTR cams as well.
Thanks
Old Feb 28, 2002 | 09:20 AM
RedlinedVTEC's Avatar
Default Re: Question about 310cc injectors (lube)
I'd definately clay the pistons when you install them to make sure you'll have clearance. I'd also recommend the 310's and bumping up the fuel pressure. Remember rich is better than lean.
Old Feb 28, 2002 | 10:41 PM
shivic's Avatar
Default Re: Question about 310cc injectors (RedlinedVTEC)
please newbie
leaner is always meaner!
Old Mar 1, 2002 | 05:10 AM
lube's Avatar
Default Re: Question about 310cc injectors (shivic)
Will I need the 310cc injectors for the CTR pistons?
Can I use the stock injectors for the JDM ITR pistons?
PS Please, no more stupid comments. These are the kinds of responses I get on CSi.
type B16
Oct 5, 2006 04:06 AM
b20vtech
Mar 9, 2006 06:24 PM
youngstunna
Jun 10, 2004 01:35 PM
deftones0817
Sep 7, 2003 07:14 PM
