HELP! Rebuilt motor and head leaks oil
After some fun with a turbo and my f22 motor blew, i had to rebuild my motor... after reassembling the motor with no turbo there is a leak out of rear pasanger side where the head and block seal together, i used all stock parts for rebuld but did not replace the head bolts what should i do to seal this better... if i take the head off again and retorque do i have to replace the head gasket again and the head bolts please help... thanks
Re: HELP! Rebuilt motor and head leaks oil (cl4show)
you didnt replace the head gasket?
replace that then start from there
if you DID replace it
your gonna need to torque it down in correct order.
Re: HELP! Rebuilt motor and head leaks oil (KAMiN)
i did replace the head gasket and torqued all bolts with factory tightening sequence and torque specs
