The shiftlinkage pin?
Old Feb 23, 2002 | 05:39 AM
97hb's Avatar
Default The shiftlinkage pin?
How do I get the shift linkage pin out? I tried for about 2 hours with no luck. I am about to just pull the engine with the linkage hookup up because its pissin me off. Also does anyone know about the alternator. The swap came with the alt. and it has a 3 pin plug, and with the civic wiring harness has 4 pin plug. Does anyone know how to wire this? Thanks for all the replys.
Old Feb 23, 2002 | 06:25 AM
93civic_b18b1's Avatar
New User
Default Re: The shiftlinkage pin? (97hb)
use a 3/8 inch tap.....they look like big ******* needles......takes me about to hits with the hammer and it pops right out
Old Feb 23, 2002 | 07:56 AM
bryant's Avatar
Default Re: The shiftlinkage pin? (93civic_b18b1)
Take your time also. You dont want your tap to take place of the pin when you tap the pin out.
Old Feb 23, 2002 | 08:43 AM
jetli6969's Avatar
New User
Default Re: The shiftlinkage pin? (CR-X)
air hammer...
Old Feb 23, 2002 | 09:13 AM
nikitad's Avatar
Go to home depot, buy a 3/8" rod. Cut offf a piece like 6" and use it as a tap.
I think it took me no more then 2 minutes to get the pin out.
Good luck.
Old Feb 23, 2002 | 02:18 PM
Lsos's Avatar
I used an 8mm punch. Worked great.
Old Feb 23, 2002 | 02:27 PM
scratchback's Avatar
Default Re: The shiftlinkage pin? (Lsos)
If you cant get any where, use the a/c tensioning bolt. Works great without having to buy tools!
Old Feb 23, 2002 | 02:51 PM
HybridFI's Avatar
Default Re: The shiftlinkage pin? (scratchback)
that's is what I did
Old Feb 23, 2002 | 05:06 PM
Kamin's Avatar
Default Re: The shiftlinkage pin? (HybridFI)
8mm punch
worked awesome
took about 5 minuets didnt just pop out but once it started to move it came right out .
Old Feb 23, 2002 | 05:08 PM
DragII's Avatar
25 Year Member
Default Re: The shiftlinkage pin? (KAMiN)
I used a bolt just smaller than the pin...you really have to beat the **** out of it...so If it's not moving...hit it harder
Old Feb 23, 2002 | 05:46 PM
sackdz's Avatar
Default Re: The shiftlinkage pin? (DragII)
I took mine out with a punch, is it hard to put back in?
Old Feb 23, 2002 | 06:18 PM
hybrider's Avatar
Default Re: The shiftlinkage pin? (sackdz)
that had to have been the most nerve racking swap experience of mine!
damn pin
Old Feb 23, 2002 | 08:39 PM
therealciviczc's Avatar
Default Re: The shiftlinkage pin? (hybrider93)
What is the advantage of a pin? My friend lost his, so he replaced it with a bolt of the exact same size. The bolt has been on there for about a year, and he hasn't had any problems (like it vibrating out or anything). So why a pin instead of a bolt?
Old Feb 24, 2002 | 01:59 AM
Charles B.'s Avatar
Default Re: The shiftlinkage pin? (therealciviczc)
That's the same question I have asked myself. Anyone have an answer? But yea, 8mm punch pin and a hammer.
Old Feb 24, 2002 | 10:10 AM
97hb's Avatar
Guys, thanks for all the replys. I use the ac tensioning bolt and about 3 wacks and it came out. If I knew it was that easy, it would have saved me alot of cussin.
Dr. Charles
Old Feb 24, 2002 | 02:45 PM
jetli6969's Avatar
New User
i still think the air hammer is the best.. cuz sometimes you cant get a good swing due to your positioning.
Old Feb 24, 2002 | 03:02 PM
89HF's Avatar
New User
Me Too!Hold it in the middle w/visegrips and whack it w/a BFH!Just don't use an A/C tensioning bolt that you plan on using again.Sometimes if it's pointed on the end,you may need to grind it flat.Happy Whacking!
oranginal
Jul 25, 2010 07:52 AM
Steve Berman
12
Feb 19, 2003 07:30 AM
mmuller
Dec 28, 2002 09:46 PM
redline201
Oct 3, 2002 08:14 PM
immortal
Feb 16, 2002 08:27 PM
