STR blockguard with CRV block?
Old Feb 23, 2002 | 08:36 PM
Ri5e's Avatar
Default STR blockguard with CRV block?
I was wondering if the STR Blockguard for the B series will work with a B20B?
Are the water jackets the same size for all B series, regardless of bore size or sleeve thickness.
thanks.
Old Feb 24, 2002 | 05:27 PM
Ri5e's Avatar
Default Re: STR blockguard with CRV block? (BG Boost)
up you go
Old Feb 24, 2002 | 09:19 PM
MugenSi00's Avatar
I don't believe it will fit. If I'm not mistaken, the b20 gets its extra thickness by taking up more of the waterjacket then the LS block does.
Old Feb 24, 2002 | 09:21 PM
RedlinedVTEC's Avatar
IMO opinion those block gards are crap. Reduce cooling and can actually weaken the cylinder bore strength (long discussion from Endyne's board). I say sleeve, you'll be way happier in the long run (judging by your sig you look to make a lot of power). Do it right the first time.
Old Feb 25, 2002 | 04:50 AM
Ri5e's Avatar
Default Re: STR blockguard with CRV block? (RedlinedVTEC)
The STR one does not reduce cooling. This guy i know has one in his 351 WHP GS-R @ 12 PSI daily driven. And has no problem with it.... so dont judge a product just because Endyn said this, Endyn said that...
Old Feb 25, 2002 | 10:53 AM
Actually I know people who have warped heads using those block guards. You asked for opinions and got them. Don't be cheap resleeve the block.
Old Feb 25, 2002 | 01:20 PM
Ri5e's Avatar
They probably used the Nu Formz blockguard. I'm only gonna be running like 10 PSI, why would I need to waste money on resleeving the block?
Old Feb 26, 2002 | 07:07 PM
#417R's Avatar
If you are only gonna run 10 psi then why even waste the time putting in a block guard?
bui1528
12
Jan 1, 2010 08:42 PM
dizzyroc88
Mar 21, 2004 06:07 AM
Mad "b00sted" Max
Aug 12, 2003 09:05 AM
toooslow
Jul 10, 2003 08:31 AM
madman604
May 23, 2003 04:19 PM
