Throttlebodies and other parts interchange (B series)?
LSVtec questions
I'm using a '95 B18B1 engine, '93 LS tranny, and planning on a 99 Si head. Here are the questions-
-Which starter- '93?
-Will a 94-95 Del Sol Distributor work?
-'92+ flywheel and clutch, correct?
- LS manifold sensors idle mechanisms will transfer to Si head?
- Any B series header or are B16 and B18C headers different?
Thanks very much
Ben
[Modified by Bnjmn, 11:17 PM 2/26/2002]
Thanks very much
Ben
Re: LSVtec questions (Bnjmn)
what car is this going in?
yes on the clutch
the only diff in the headers is possibly the # of o2 sensor bungs
the sensors should swap over from the ls to the si head
the starter will work
the dist, im not sure of, it might, but it might not, can you get one from a 99 si?
yes on the clutch
Re: LSVtec questions (crxfactor1991)
I'm going OBD-1 in a 91 CRX DX, so no '96+ distributors.
On the starter- will a '94-'95 work as well? They seem to be cheaper.
Thanks
Ben
Thanks
Ben
