91 std---->b16a question.
Old Feb 21, 2002 | 10:53 AM
rainforest's Avatar
Default 91 std---->b16a question.
ok i did all the wiring i have 2 probs though. 1 ther are 2 white wires on the dist and iam not sure where each one goes. ok so the next question is when you do the yel/blk wires from the dx injectors to the yel/blk on the inj resistor box do you just cut the wires and solder the 2 yellow/black wires together and connect them to the yel/blk wire from the inj resistor box. because thats what i did.
Old Feb 23, 2002 | 07:36 AM
4gvtec's Avatar
Default Re: 91 std---->b16a question. (rainforest)
on the white wires one has a red dot on it but when you touch the to ,the red rubs off.any way it happen to me several times.the car only starts when you get the to wires wired right.second ,yes the two dx black yellows wire togather to the one black yellow on the resistor box.hope this helps!
d15bfi
Sep 28, 2008 10:58 AM
Dunc
Oct 2, 2005 02:12 PM
BoostedD15B7
Nov 1, 2003 06:45 PM
