ls crank ?
Old Mar 4, 2002 | 10:32 AM
GokuSSJ4's Avatar
Default ls crank ?
what are the differents on a ls crank compare to a gsr and also an itr crank?
also which would be better to run for all motor and especially on a high rev motor ?
Old Mar 4, 2002 | 11:55 AM
Sleeper's Avatar
Default Re: ls crank ? (Spoon1)
LS/B20 crank is 89mm, difference is 1.8mm, B18C/B18C5 uses the 87.2mm crank. There is no replacement for displacement, except boost!
Old Mar 4, 2002 | 09:31 PM
ekekek's Avatar
Default Re: ls crank ? (Sleeper)
yeah, sleepers right. they are both good for all motor and you could say that the ls is better because it can produce more torque. however the gsr and itr are more rev friendly. it can spin faster but ever so slightly.
Old Mar 5, 2002 | 08:39 AM
GokuSSJ4's Avatar
Default Re: ls crank ? (ekekek)
thanks guys , reason im going to have a shop build me a 2.0l and they say that they would use ls crank ,but i like gsr and itr for reving high cause there design for high revs .
Old Mar 5, 2002 | 12:28 PM
GokuSSJ4's Avatar
ttt
Old Mar 5, 2002 | 01:40 PM
ekekek's Avatar
the ls and crv crank have the same stroke so it makes no difference. if you use the gsr crank in the crv block, you will have around 1900cc - 1950cc because of the 84mm bore. that way you can still get good revs and high torque too.
1SLaMMeDC2
Jul 22, 2010 10:14 AM
94dc2
Jan 24, 2008 03:11 PM
OC Geezer
23
Nov 24, 2007 01:00 AM
ProjectBoosted
Oct 23, 2006 10:02 AM
