Swap Gurus: I've ran my vtec and knock wire in from my b18c5 swap already and...
already completed the OBDI to OBDII. But now I want to go with a p28 ecu. Do I still need both wires? How do I pin it into the OBDI ecu harness and will I have and check lights? Thanks.
Former Moderator
Re: Swap Gurus: I've ran my vtec and knock wire in from my b18c5 swap already and... (jonnybravo)
No need for knock sensor with a P28 ECU. nor do you need the crank fluctuation sensor, second 02 sensor, etc. that all go with OBDII stuff.
BTW: I'm not saying knock sensor is OBDII specific. Just that the P28 will not read for it or OBDII crap
Goto Honda and ask if you can buy/have some ECU pins.
nonpoint986
08-31-2009 04:37 PM
